Proper motor oil for 99 D2
Old Jan 3, 2007 | 07:44 PM
jskrebs's Avatar
Default Proper motor oil for 99 D2
Hi,
Had my D2 for several months now. Love it!
Recently had the head gaskets replaced. Mechanic filled the motor with 10W30 from his 55 gallon drum. about 1000 miles later we were on a trip and the oil was down by 3 quarts. Had my wife stop by to have the machanic check it out and they could find no leaks. The car runs fine, no smoke, coolant is very clean. The mechanic thought that perhaps the Rover motor may need a "special oil"? Perhaps Synthetic and a different viscosity?
Any ideas?
Jeff
99 D2
Old Jan 3, 2007 | 08:05 PM
Default RE: Proper motor oil for 99 D2
Sounds strange, you shouldn't loose that sort of oil no mater what weight you are using.
I would suggest you pull all you spark plugs and see if you have a wet/ fouled plug from oil burning.
I am in Colo and run 5/30 in the winter and 10/40 in the summer, when I did alot of trails in the high deserts of Calif, I ran 20/50 to counter act the heat.
Mike
Old Jan 3, 2007 | 08:39 PM
jskrebs's Avatar
Thanks Mike, would I not see some blue smoke from oil burning?
Old Jan 3, 2007 | 09:11 PM
Yes, you should but you're not leaking and it has to have gone somewhere.
Mike
Autogeek
Detailing
Oct 13, 2009 10:12 AM
AK Rover
Aug 25, 2008 06:27 PM
alpinab7
Aug 17, 2006 09:54 AM
Evian
Sep 10, 2005 01:39 AM
