Propylene Glycol Coolant/Antifreeze
Old Oct 29, 2016 | 01:42 PM
Columbiar's Avatar
Default Propylene Glycol Coolant/Antifreeze
Been looking at this due to my small coolant leak that I haven't had a chance to fix. Would be a lot safer for the pets. Any opinions on the performance?
Old Oct 30, 2016 | 10:46 AM
chubbs878's Avatar
Nu uh. Ethylene glycol and distilled water only. Performance additives such as Water Wetter are also recommended. DexCool in the '00s killed these trucks. Now we stick with what works. No more experimentation needed. Those "latest & greatest, Eco-friendly" chemicals corroded the cooling system from the inside-out. If you still have the Tropical Punch KoolAid looking stuff in your truck you should have flushed that out the day you bought it.
Old Oct 30, 2016 | 11:28 AM
number9's Avatar
Propylene glycol has been around for years and often used as an antifreeze in unused potable water systems but is more corrosive and has different properties than ethylene glycol. Some mfgs. now seem to offer it with anti-corrosive additives as a more environmentally friendly, "pet safe" & usually more expensive coolant.
Short term use of cheap RV quality to save a few bucks or if worried about your pets would not likely cause severe corrosion overnight.
As chubbs878 said it's best to avoid.
Niver39
Jun 20, 2016 09:50 PM
DiscoCam
Oct 6, 2015 08:47 PM
RROJ
23
Dec 1, 2010 12:53 AM
Kennydhl
Aug 3, 2005 05:28 AM
