Pulling this trim peice
Old Aug 22, 2018 | 07:56 AM
zuke's Avatar
Default Pulling this trim peice
I need to get this piece off my parts car without breaking it. Any body know how to do?
Old Aug 22, 2018 | 08:35 AM
CollieRover's Avatar
Mine busted so I can see behind it. It is held in place by two screws hidden behind the interior trim piece.
Old Aug 22, 2018 | 02:17 PM
jamestfl's Avatar
Yeah, that's a bit of a PITA to get to. Is effective for holding it on though. Just a pain. Behind interior trim piece.
Old Aug 22, 2018 | 02:32 PM
akrover90's Avatar
Yea, my bottom connection point on that trim piece is broken so I can see it vibrating on the highway. I keep meaning to fix it, but it does look like a PITA so I keep putting it off.
Old Aug 22, 2018 | 03:47 PM
Paul Grant's Avatar
You have to remove the upper and lower rear panels for the best access. I guess you could just remove the top panel and pull away the lower one. What you'll fine are three round black pieces of tape on the interior side of the body pillar (see photos). Remove those three pieces of tape. You'll need a 7mm socket, an extension and an impact wrench if you have one. The nuts aren't on the three studs that tightly but rust can be an issue and I've had a lot more success with a 3/8th impact as opposed to using a common wrench. I guess the impact helps to jar the nut free. A little easing oil won't hurt either.
Attached Thumbnails Pulling this trim peice-img_1279.jpg   Pulling this trim peice-img_1280.jpg   Pulling this trim peice-img_1281.jpg
niceflipflop
May 23, 2023 09:56 PM
Gator996
LR4
Jun 16, 2018 09:37 PM
jna97
Dec 31, 2016 04:13 PM
cer308
May 16, 2012 09:33 AM
humroot
Aug 22, 2010 07:33 PM
