Puppy Parlor
#31
#32
#34
#36
Good grief that's cheap. 1.55 for TWO? I spent a thousand on dogs this month, and the month isn't over.
On a positive note, I retrieved the Rover from the Homestead this weekend for this project and it ran perfectly. Sitting for almost two months. Wife snuck over and cleaned it. I'm a lucky man, on both fronts.
#38
This is a true community effort. I'm going to give everyone a puppy when this is done.
#39
https://www.ebay.com/itm/Mighty-Mule-FM500-MM500-Parts-HB100-Hardware-Brackets-Set-FM500-MM500/283071725750?epid=1957250843&hash=item41e863c0b6:g :zpUAAOSw~OdVYBHr
I should point out that if the dog barrier is solid and does not go to the roof of your truck, you only need the L brackets and some wing nuts. If you are making something full length from floor to roof definitely get the roof mounted brackets that was suggested.
