Purchased a purge valve but it came with a wire, I have no idea what it is for...
Old Jun 12, 2020 | 03:38 PM
GoRoll's Avatar
Default Purchased a purge valve but it came with a wire, I have no idea what it is for...
Purchased a purge valve at Atlantic British but it came with this wire and I have no idea where it plugs. One end plugs on the valve but the other end, I have no idea.
But the valve I purchased fit in my vehicle with no issues.
Old Jun 12, 2020 | 03:40 PM
GoRoll's Avatar
Trying to figure out what all these codes so I'm trying to go with small items from what I've researched.
First 3 will be purge valve, canister vacuum and spark plug wires... Even tho I changed my wires a month ago...
Old Jun 16, 2020 | 06:45 PM
Llamasayswhat's Avatar
What scan program is that? your codes are all wrong. They are mixing up codes and verbage. Download Torque for your phone and use that
p0305 is a cyl 5 misfire
p0462 is a fuel level range fault
p0171 is lean condition on bank 1
p0132 is an O2 sensor overvoltage fault for b1s1
p1171 is rich condition bank 1
p0300 is correct - random multiple misfires
Old Jun 16, 2020 | 06:48 PM
That harness looks like an extension/jumper harness. Not sure why it came with your valve.
Did you run out of fuel? Is your purge valve sticking? A stuck valve can cause both a lean and rich fault and can cause a single cyl misfire
Old Jun 16, 2020 | 07:08 PM
Richard Gallant's Avatar
That is a jumper wire for a different vehicle, these purge valves are used by a bunch of different auto manufacturers. The jumper just lets it plug into a different wiring harness
Old Jun 17, 2020 | 02:46 AM
JUKE179r's Avatar
You don't need that wire assembly.
Friday Night Disco
Aug 4, 2021 03:12 PM
TOM R
Jun 14, 2016 11:21 AM
Joshman
Mar 3, 2014 06:24 PM
eve6er69
Jul 22, 2012 01:54 PM
disco2hale
Dec 30, 2010 05:45 PM
