Purchased Used 04 Disco - Dreaded Three Amigos
Old Jan 21, 2009 | 09:55 AM
Sbonomo's Avatar
Default Purchased Used 04 Disco - Dreaded Three Amigos
I just bought a new 2004 DII with 63k miles. While driving the ABS, hill decent and TC light came on (along with the brake light). I have read many posts about the "three amigos" and think that this could be the same problem i am having. I was in the mountains this weekend and noticed that the pedal did not pulsate when I was braking in the ice leading me to believe that the ABS is not working. Also, my case is a bit different because my disco has the Old Man Emu lift (i think it is the 3'). Would/could the lift cause the lights to come on? I have scheduled an appointment with the dealership to have them check the codes any thoughts/advice would be greatly appreciated
Old Jan 21, 2009 | 10:05 AM
salve7's Avatar
Default RE: Purchased Used 04 Disco - Dreaded Three Amigos
I would avoid the dealership if possible... find a indy mechanic.
Old Jan 21, 2009 | 10:32 AM
You might want to send me your tel number and lets talk about your concerns.
The OME is not a 3" and shouldn't be effecting the t/case.
Old Jan 21, 2009 | 03:20 PM
starcraft's Avatar
If your brake light came on then you are probably low on brake fluid. Check for leaks ....... mine was leaking from under the brake reservoir once. If you are low on brake fluid, I believe this can cause the ABS lights to kick in. Try filling up the tank and then see if the lights come on again. Also make sure you find the leak or else you will loose the brakes all together. Good luck
seaosrover
Nov 14, 2010 03:07 PM
Sbonomo
Jan 24, 2009 11:09 AM
acegt1
Jun 3, 2008 12:56 PM
Maine Disco
Dec 2, 2007 12:12 AM
OlDood
Jul 4, 2007 10:23 AM
