Purge air from radiator
Old Mar 21, 2010 | 06:35 PM
bantham1's Avatar
Default Purge air from radiator
I am still having a waterfall sound under my dash. Will the air escape from the system with my reservoir cap on? If not, I will follow the purge procedure with the engine cold again and purge the system with the cap off of the reservoir. I may try to switch the heater hoses if this does not work. Any suggestions?
Old Mar 21, 2010 | 06:44 PM
No it cannot escape with the cap on, it is a closed system.
If it is a small air pocket it may, but not a big one.
Old Mar 21, 2010 | 07:22 PM
bantham1's Avatar
I will try to purge with the coolant cap off then. Will squeezing the upper radiator hose assist in removing an air pocket while purging?
Old Mar 21, 2010 | 07:36 PM
No.
Just follow the instructions in the write up section.
Squeezing the upper hose will only suck air in.
Doing it properly can take 30 mins but thats what you have to do.
Follow the instructions.
Old Mar 22, 2010 | 06:33 AM
Rovin4life's Avatar
I never have issue, I just take off the hose cap and pour water in till its full.
Old Mar 22, 2010 | 10:15 AM
First, stop what you are doing before you toast your engine from over heating. It is obvious that you do not know how to purge/bleed the system so send me your tele number and I'll call you.
BuckMontecristo
Jul 27, 2006 10:19 AM
