Putting a 4.0 in my '04
Old Dec 30, 2014 | 02:32 PM
toad2's Avatar
Default Putting a 4.0 in my '04
I bought a 2002 yesterday with a 140k (km) on it and i am gonna put it in my 04. No misfires, sounds great.
Only problem is no sai while our 04 does. I know people will say swap the heads, and put new gaskets on but i would rather not touch it and just put it in.
What is the worst that will happen? Engine codes?
I can live with codes.
Edit: We do not have emissions tests here.
Old Dec 30, 2014 | 03:12 PM
dusty1's Avatar
yeah if you don't need the sai......do away with it
there is a write up on here I think
edit maybe not, but it looks like a new ecu will fix the code issue
https://landroverforums.com/forum/di...ion-sai-58802/
Old Jan 1, 2015 | 01:49 PM
drowssap's Avatar
Youre going to have to do do the head gaskets at some time, much easier on the floor than under a hood
Old Jan 1, 2015 | 08:12 PM
toad2's Avatar
Sure, but what if you break or strip a head bolt? or have to plane a head? Where do you stop? Check the bearings?
Idk, it runs good, think I'll just put it in and pray.
Old Jan 2, 2015 | 03:54 AM
abran's Avatar
I agree. Doing the heads out of the car is heaven. I bet it takes half the time than it would in the car. The first head gasket job I did was out of the car and the whole time I was wondering why everyone says it is a pain!
Old Jan 2, 2015 | 11:49 AM
toad2's Avatar
So I noticed in your sig that you have an 04 with a 4.0l. Did you do the swap? Is the wiring harness all the same? Did they both have sai?
Any info or tips would be appreciated.
Old Jan 2, 2015 | 12:29 PM
abran's Avatar
Both were SAI equipped. I have to admit that I did not do the swap, a local mechanic did. I was there for a day and it was a direct plug and play swap.
Putting an SAI motor in a non SAI car would be easier I would think(just plug the ports)If it were me I would put the SAI heads on and make it a plug and play swap. That is the only difference in the motor.
Old Jan 2, 2015 | 02:36 PM
toad2's Avatar
From what I can find its still plug and play, I'll just get sai codes.
Old Jan 2, 2015 | 04:15 PM
abran's Avatar
Agreed, kind of. You will have connectors on your harness which are not plugged in.
Old Jan 17, 2015 | 06:28 PM
toad2's Avatar
So, had it running today and out for a test drive. Seems to run great, no codes so far.
