It putting ground on intake plenum ok?
Old Feb 22, 2025 | 10:29 PM
evil_goat's Avatar
Question It putting ground on intake plenum ok?
When I put my engine in, the grounding strap was either missing or lost, so I rigged up this. It lasted and didn't seem to cause any problems.
I got an actual grounding strap to replace this with, but once I got the bolt out of the head, I could not get it back in. I think I need to take off the intake plenum and that rocker cover to get it in there. Is it ok if I move the ground to the intake plenum instead?
Old Feb 23, 2025 | 03:00 AM
Extinct's Avatar
Should be no problem.
Old Feb 23, 2025 | 08:02 AM
H20nSnow's Avatar
…or it will be.
Remember that you made this change. If you start having inexplicable issues with spurious codes and dash lights, then move it back where it belongs. But, it should be no problem.
Old Feb 23, 2025 | 08:39 AM
mollusc's Avatar
Isn't there a non-conductive gasket between the intake plenum and the rest of the engine?
Old Feb 23, 2025 | 08:54 AM
H20nSnow's Avatar
There is, but the bolts create a path. The problem is that fasteners make notoriously poor, unreliable conductors. That’s why I warned to remember that this was done. This could crop up as an issue years down the road.
Old Feb 23, 2025 | 02:23 PM
evil_goat's Avatar
Since the ground was originally on the head, the head gasket is also non conductive, so I think this would work.
Old Feb 23, 2025 | 05:39 PM
Extinct's Avatar
Besides the intake bolts (12) you have the compressor bracket and waterneck bolted to it. It will be fine.
Poway
LR4
Aug 25, 2023 06:57 AM
Poway
Range Rover L322 (3rd Gen)
Aug 24, 2023 06:59 PM
Jason_B
Jul 10, 2021 12:54 PM
mudpuppy229
Jul 4, 2017 11:51 PM
chubbs878
Dec 24, 2015 08:44 AM
