Putting a non-rover motor in a rover?
Old Jan 12, 2011 | 04:51 PM
Draayer's Avatar
Default Putting a non-rover motor in a rover?
Would it be possible to put a non-rover motor in a rover? I'm looking at a 2000 disco 2 that has a blown motor, I read about all the head gasket problems etc and I'm wondering if there is a motor out there that would be a bolt in replacement (or maybe just different motor mounts) like a chevy, ford or something else? Or would it be more work than it's worth?
Thanks,
Old Jan 12, 2011 | 05:56 PM
Bryan H's Avatar
Unfortunately, the consensus will be no. The only semi-realistic option is a rover diesel, which is still an expensive option. All other swaps (GM smallblock or anything else) will be cost prohibitive given the value of the truck. Sorry, I wish there was something that would work too.
Old Jan 12, 2011 | 06:09 PM
buick215's Avatar
There is no other engine that is a bolt on replacement. All other engines will end up costing more in the end due to extensive modifications.
Old Jan 12, 2011 | 08:11 PM
humroot's Avatar
In my opinion, it's not worth it. Way too expensive and you will need to upgrade the drivetrain to handle extra power.
Here is a link to a conversion kit for a Chevy V6 or V8.
http://www.marks4wd.com/products/eng...evy-V6-V8.html
Old Jan 13, 2011 | 09:02 AM
What is wrong with the engine? How much are they asking for the Disco?
Old Jan 13, 2011 | 10:01 AM
jbarr89's Avatar
Thanks,
anything is possible, just depends on what it's worth to you and how fat your wallet is! I agree with others that you would have to change out your drivetrain as it's just not suited for the torque of a chevy or ford engine but sure it can be done. I wouldn't mind doing it myself if I had the time or money.
Old Jan 13, 2011 | 11:41 AM
Bryan H's Avatar
The other challenge with a swap is emissions legality. Swapping an older engine or engine from another manufacturer is not allowed in many states.
Old Jan 14, 2011 | 07:58 AM
Draayer's Avatar
Default The seller wants $1,200
The Disco II is a 2000 with 90K miles on it and all the seller said was that the motor was burned up and he wants $1,200. I found it interesting that he also said (at 90k miles) that it has a new trans, drive train and water pump.
It's too bad the chevy conversion kit cost so much, that might be a good way to go.
Anyway thanks for the advice.
minet
Sep 12, 2012 10:14 AM
Draayer
Feb 6, 2012 07:44 AM
leddifer
Audio/Visual Electronics
May 15, 2010 05:02 PM
Gordon Bombay
Feb 25, 2010 09:46 PM
Mee
Aug 11, 2005 12:43 PM
