Is this a quality thermostat ?
Old 01-02-2019, 04:05 AM
JUKE179r's Avatar
Originally Posted by shanechevelle
Oh, make sure you buy an ultragauge
THIS!!!
Old 01-02-2019, 07:01 AM
OverRover's Avatar
And one of these...………….
Old 01-02-2019, 01:27 PM
Sandman614's Avatar
Originally Posted by Best4x4
I've always bought the Britpart 180F thermostat from Lucky8. It's always come in a Britpart box with a Britpart P/N: Sticker and some boxes even had a Defender on the box. Well I ordered one before Christmas and it arrived today. It was not in a box (just rolled up in bubble wrap). It does NOT look like the 20+ Britpart thermostats I've installed in the past 2 years. In fact it's identical to a 12.00 Ebay cheapo I currently have in the 02 D2 Westminster. My ebay cheapo is stamped 82C and it does not open at 180F (I suspect it opens at the OEM temp of 195F aka mis-marked el cheapo thermostat). The normal Britpart unit was always stamped 78C on the thermostat itself. I also noticed the unit I was shipped had the mount a Freelander uses (D2 thermostats don't mount to anything). The normal Britpart thermostat I've used in the past 2 years does not have that.
I've messaged Steve with Lucky8 about this issue.
This could explain why some people that bought the Britpart units were having issues as it's like what I experienced years ago with my Hummer H3's and mis-marked thermostats that were supposed to be 180F but in reality they were 190-195F units.
Do you have any knowledge of the factory PEL500110 thermostat? There's no seemingly noteworthy markings on this one I bought from Amazon.
Old 01-02-2019, 01:57 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
If it’s grey = OEM, looks legit to me with the LR box & it’s grey.
Old 01-02-2019, 02:34 PM
Dave03S's Avatar
Put it in a pot of water and watch for what temp it opens... Then you will know just how legit it is. But it looks like the Britpart grey OEM.
Old 01-02-2019, 03:18 PM
Best4x4's Avatar
Britpart 180F = 30.00-40.00 Black stamped 78C inside, and no Freelander mount tab
LR OEM 180F = 60.00-80.00 Dark Grey, no Freelander mount tab
Ebay el cheapo = 12.00 Black, stamped 82C inside, Freelander mount tab & it DOES not open at 180F (more like 187F to 193F)
Old 01-02-2019, 04:14 PM
I always have had success on the Atlantic bristish soft spring warm weather stat. Truck runs 194-199
oh ya get a ultra gauge
Old 01-04-2019, 08:36 AM
DiscoBuckeye's Avatar
I replaced my Motorad 180 with a Britpart 180. Now I sit at 190-198 at warm idle instead of 205-210.
Old 01-04-2019, 10:28 AM
I live in South East TX where it gets nice & hot during the summer, I own 3 very well kept D2's and all of them run the Britpart Thermostat. I initially bought one for a customer on a budget (I used the LR Grey 180F up until then), It worked great & after that I started using them instead of the LR unit unless I was told to use OEM parts. I haven't had one come back with an issue and like I said I've installed a lot of them.
My advice on ANY Thermostat you buy = toss it into a bowl of boiling water and using an infrared Thermometer monitor the temp when it opens.
If I didn't trust that Thermostat it wouldn't be in a single one of my LR's!
i find putting it into a bowl of boiler water is not even close to being accurate it does not mimic real life events as you boiler the body as well.
It’s not reliable at all
I’ve tried and doesn’t work
Old 01-04-2019, 11:25 AM
Best4x4's Avatar
I’ve done it several times and used an infared thermometer and it’s been darn close. Not exactly like 180F but the main thing is to test if it opens/closes.
Mis-marked thermostats especially el cheapo’s are out there!
Quick Reply: Is this a quality thermostat ?
