question about ckrankshaft on TD5
Old Sep 22, 2022 | 07:25 PM
dtorres265's Avatar
7th Gear
Default question about ckrankshaft on TD5
hello,
I have a TD5 2004 since some months actually two and I had this unlucky situation today on where I was driving and I noticed and sign on the dashboard and I lost the brakes and the hydraulic on the drive, as I was close to home I drove slow till reaching home. When I open the hood in order to see what's going on I noticed that the belt was not moving and I observed that the crankshaft was not moving.
The records that I have is that the crankshaft has been replaced 30000 kms ago, can somebody provide some insights on what could cause this, could be a bad tension on the bolt that holds it or what could be the problem?
thanks in advance.
Old Sep 23, 2022 | 04:20 AM
mollusc's Avatar
I think you mean the crankshaft pulley.
I don't know the TD5 engine, but on the V8 engine the bolt for this pulley is extremely tight (270Nm). Perhaps whoever worked on it did not get yours tight enough and it came loose.
Old Sep 24, 2022 | 11:44 AM
frostythor's Avatar
Well that is usual, as the crank bolt torque is 460nm, or 340 ft lbs, and it has a woodruff key in it as well, maybe the key was missed when the belt was replacd its easy to do
Old Sep 24, 2022 | 02:38 PM
dtorres265's Avatar
7th Gear
Originally Posted by frostythor
Well that is usual, as the crank bolt torque is 460nm, or 340 ft lbs, and it has a woodruff key in it as well, maybe the key was missed when the belt was replaced its easy to do
finally we got resolved yesterday, the problem was that the bolt was weak and the seal that had was not the correct one, we did that with 460nm and now seems to be running smooth so far.
thanks for the guidance
much appreciated.
Old Sep 25, 2022 | 02:49 AM
frostythor's Avatar
do you have a manual for the TD5, if not PM me your email and i will send you a pdf copy
Old Sep 27, 2022 | 06:20 AM
dtorres265's Avatar
7th Gear
hello, yes I do I also found it in spanish as is my primary language as some terminology in English in not than easy for me.
thanks again.
za105
Oct 24, 2020 09:20 AM
diverjohn52
Apr 3, 2011 01:27 PM
NiteTrain
Jan 1, 2011 06:41 PM
Disco100
Mar 29, 2010 05:47 AM
pedro tomas
Feb 8, 2006 10:36 PM
