Question about OBD dongles for iphone / ipad
I used the Torque app on my phone for a while but ended up installing separate individual gauges for temp, oil press, and voltage. The app was pretty useful but I'm paranoid about temp, so I wanted numbers completely independent of the factory computer.
I do still use Torque to check codes.
I'm currently using a scangauge, however I've started to collect the parts for an in-dash computer and think I'm going to use a Linux based app that will talk with any of the cheap Bluetooth dongles.
The reason I didn't go with a blue tooth dongle In the first place is that A: I don't want an iPad in my way all the time. B: I didn't want to have connectivity issues with components that had to reboot every time I start the vehicle, and have to deal with battery powered components.
With the on board computer, everything will be working in the background all the time, I'll have navigation, diagnostics, WiFi, Internet, audio and video control, etc. And it will all be in a double din enclosure. No giant ipad on the dash or wedged in the console, no GPS on the windshield, no scangauge on the dash, etc.
I use UltraGauge Blue OBD dongle to connect to my iPhone or iPad mini. You can customize the gauges that you specifically want to monitor. I've had no issues with Bluetooth connectivity between my Sony radio or the dongle.
Even when my Disco is turned off, I leave the dongle connected in the OBD port. I've left it in for over a week while on holiday and it didn't drain my Disco's battery.
missler
04-03-2014 06:19 PM
