Question about small coolant line from radiator
Old Jan 8, 2022 | 08:24 AM
me 2's Avatar
Default Question about small coolant line from radiator
Just curious if that small skinny hard hose going from the drivers side radiator to the coolant reservoir was needed?
Old Jan 8, 2022 | 09:12 AM
Brandon318's Avatar
Very much so.
Old Jan 8, 2022 | 11:16 AM
The Deputy's Avatar
Yes, needed. If replacing, use copper tubing and bent your own. Do not use rubber hose, unless routing it another way, since the top radiator shroud will collapse the rubber hose (when routed through original location, two grooves in radiator shroud) and not allow proper flow.
Old Jan 8, 2022 | 02:18 PM
me 2's Avatar
Ok, just curious, trying to burp the coolant system still, but I guess it’s not really In the way. Thanks
Old Jan 8, 2022 | 06:26 PM
Extinct's Avatar
I usually replaced with ATF cooler hose, run in front of the radiator instead of over the top. Copper line is a good idea though.
themdg
Apr 11, 2018 01:00 PM
samue23
Mar 1, 2012 05:49 AM
calebbo
Dec 13, 2010 09:34 PM
MaverickTye
Freelander
Jun 2, 2010 11:59 AM
Evian
Sep 10, 2005 01:39 AM
