Question about tail lights...
RE: Question about tail lights...
Thanks Mike, I do always replace in pairs but have not had to since purchasing the rover. Are the bumper lights brake lights or driving lights and if both are not working is there anything other than bulbs to consider? Are they running from a different fuse?
There should be a switch on the binnacle around the steering wheel with a rear fog light picture. That will turn on the red lights on the rear bumper. I've only used them once to see what they did. If your brake lights stop working you can manually turn on/off the rear fogs as a temporary stop light.
