Question about tire size
Old Nov 2, 2014 | 03:09 PM
jtp3672's Avatar
Default Question about tire size
New to the forum, just got a beautiful '02 Disco 2.
Before you jump on me about posting this, I am well aware there are numerous threads pertaining to tire size. However, I still haven't quite found a decisive answer yet. There seem to be a lot of opinions, many of which contradict each other.
My vehicle has the 18" rims and runs 255/55/18, which have an outer diameter of 29.043". They're definitely not optimal for off roading.
Is it possible to simply replace these with a set of 255/65/18, which would make the outer diameter 31.051"?
Some members say that 29" is the absolute largest tire size you can go without rubbing, others say 31". Does anyone have a decisive answer on this, or with the specific tire sizes above?
I recognize the need to lift the vehicle eventually, but I am doing a lot of highway driving to get out of town, and then some mild offroading, primarily in deep sand, and could use slightly larger tires with better claws without going taller yet.
The second question, which I'm sure is covered in another thread, is if these 255/65/18 tires will fit the stock vehicle, which tires are recommended for a healthy balance of highway use and off-road / deep sand?
Thanks in advance!
Old Nov 2, 2014 | 04:46 PM
cybercop's Avatar
Old Nov 2, 2014 | 05:09 PM
potxoli's Avatar
Hi,
I found this web page had the most comprehensive answer to this question:
Clifton Scientific Text Services, the Netherlands
Hope this helps.
Old Nov 2, 2014 | 05:28 PM
That is actually one of the better links for DII tire sizing I have seen
Old Nov 3, 2014 | 06:44 AM
potxoli's Avatar
I agree. We might want to cut-n-past the content into a post or sticky since websites disappear (like the Virgin Islands discoweb site seems to have gone away), but that is legally questionable.
Old Nov 3, 2014 | 07:17 AM
Alex_M's Avatar
Thanks in advance!
In short, yes they will fit. I'm currently running 30s and there is definitely room for another inch at full flex and full lock.
Old Nov 3, 2014 | 11:55 AM
Big Jim Swade's Avatar
I run 255/60-18's which are about 30" tall. Probably have enough room with 31's on stock suspension. One thing to be aware is, how much more sluggish your acceleration is with taller tires. If you pull a trailer, you probably won't like the results unless you re-gear.
MountainOx
Sep 22, 2009 12:32 AM
sixthflick
May 24, 2009 12:11 AM
flyplanes5
Nov 2, 2008 08:30 PM
jwood700
Oct 28, 2008 05:53 PM
ajh
Oct 23, 2007 10:13 AM
