Question for Ultragauge Owners
Old Sep 8, 2020 | 04:36 PM
Boostle's Avatar
Default Question for Ultragauge Owners
So the OBD2 port always stays powered even with the key out. Does the Ultragauge turn off automatically after some time or does it remain on? I'm somewhat worried about it draining the battery.
Thanks in adavance.
Old Sep 8, 2020 | 05:02 PM
jastutte's Avatar
the only time i have had the UltraGauge stay on is if i plugged it in when the Rover was not turned on.
if you have the key turned to the ON position and then plug the UltraGauge in you should be fine leaving it plugged in at all times.
Old Sep 8, 2020 | 05:13 PM
Boostle's Avatar
Thanks for the info
Old Sep 9, 2020 | 01:33 PM
NewToTheTwo's Avatar
Mine stays plugged in 24/7 and turns itself off when I turn the key off.
Old Sep 9, 2020 | 03:34 PM
nashvegas's Avatar
Yep, it does shut off. I've had no probs with it staying on after the Disco was off.
That said, I did have some issues with it sometimes not turning on. I could press a button on the back to get it on but I fiddled with it so it would reliably come on every time/I changed a setting.... I have mine set to detect a certain voltage (maybe 12.8 or something, I adjusted it up and down a few times to get the right voltage) and whenever it detects that (ie car on or running and alt charging) the screen of the UG turns on.
DeckB
Dec 5, 2018 09:11 PM
DiscoCam
Mar 21, 2016 02:05 PM
cfishkin
Freelander
Mar 7, 2013 09:29 PM
discobob
Dec 26, 2008 07:55 AM
damselindistress
May 28, 2006 12:08 AM
