Questions on testing the ABS option B
Old Jul 4, 2013 | 06:52 PM
RedCricket's Avatar
Default Questions on testing the ABS option B
I ended up pulling the whole ABS MOD out and doing it that way. My question is: When I test with the switches out of MOD I see they work properly, 3.0 open, 2.0 one closed, 1.0 both closed. When I reinstall the switches into the MOD and tighten the three 4mm screws I retest and get 0.0, Is this normal? Or should I get some kind of reading?
Old Jul 4, 2013 | 08:00 PM
iambhooper's Avatar
0.0 exactly? You should be fine if. What was it supposed to be?
Old Jul 4, 2013 | 10:18 PM
RedCricket's Avatar
I don't know exactly, I was just wondering why the circuit would read 3000ohms before being screwed in an 0 after being screwed in. Is there some sort of connection being made inside the abs mod that would cause this? Or am I shorting it out when I put it together?
The_OGCJR
Aug 2, 2014 09:15 AM
rover2003
Nov 8, 2007 04:47 PM
jblanco
Jul 31, 2005 12:49 PM
VB_Rover
Jun 30, 2005 10:48 PM
lr3dave
Feb 9, 2005 12:23 AM
