Quick cooling system question.
Old Oct 16, 2013 | 08:26 AM
james.martin1's Avatar
Default Quick cooling system question.
Is it ok to top off the coolant reservoir while the engine is warm? I opened it slowly and the coolant didn't overflow but I did seem like the coolant level in the reservoir did rise a bit. Do I need to bleed the system now? If so does the engine have to be cold first?
Old Oct 16, 2013 | 11:31 AM
Madlands's Avatar
If the engine is warm I've always topped it off when it's running.
I have never had to bleed after topping it off, and I only bleed when cold. It's easier messing with cold coolant than hot coolant when bleeding. Bleeding warm just gives you a chance to burn yourself.
I'm no expert though just speaking from personal experience.
TRIARII
Oct 1, 2014 07:43 AM
icyhot201
Aug 16, 2010 07:24 PM
Pwn777
Jun 29, 2010 06:50 PM
Rover Chris
Jun 25, 2010 07:18 AM
endneu913
Nov 3, 2007 03:46 PM
