Quick oil question help**
Old Jun 30, 2015 | 09:37 PM
jrwalk1651's Avatar
Default Quick oil question help**
Quick question I'm about to change my oil on my 1999 D2 with 120k miles I attached a pic of the stuff I'm using. I just need a simple yes or no answer. I don't want to screw anything up. I've searched every forum and this is what I've come up with.....
Mobile 1 M1-301 filter
Rotella T triple protection heavy duty diesel oil SAE 15w-40
Thank you
Old Jun 30, 2015 | 10:04 PM
abran's Avatar
Yes...
Old Jul 1, 2015 | 06:12 AM
jrwalk1651's Avatar
Originally Posted by abran
Yes...
Thank you! reason I was skeptical was because I recently moved to Chicago and I wanted to have a local shop do it and I got turned away because it was disel oil.....
Old Jul 1, 2015 | 06:28 AM
drowssap's Avatar
unless you want to spend a fortune on additives, diesel oils are the way to go. They still contain things like zinc that a flat tappet cam needs. New roller cam motor do not like zinc so it has been removed from a lot of oil.
Old Jul 1, 2015 | 07:03 AM
jrwalk1651's Avatar
Ahh I gotcha now. Still need to find a place that will throw that in for me...I have a sloped parking spot on the street (not ideal) when you talk about additives are you saying just some regular 10w-40 mobile one with some marvels mystery oil?
Old Jul 1, 2015 | 07:37 AM
drowssap's Avatar
No, do not use MMO. or any other snake oil.
Just run 15 40 Rottela or i think Mobil makes Delvac for diesels ive never used it.
Old Jul 1, 2015 | 10:02 AM
jrwalk1651's Avatar
10-4 thank you.
Old Jul 2, 2015 | 01:09 PM
Big Jim Swade's Avatar
That's the oil that I use, Walmart $12.95 a gallon
Old Jul 2, 2015 | 01:48 PM
Charlie_V's Avatar
I use the 15/40 Rotella Dino oil (have for years... since mine hit 118,000 miles)... works in everything and keeps your engine clean. In the winter, since you are where it gets real cold, you might want something thinner.
Old Jul 2, 2015 | 07:23 PM
antichrist's Avatar
The oil is fine.
There are better filters, like WIX 51515 (NAPA Gold 1515) or Baldwin B2 for less money.
http://www.bullittarchive.com/5000/5...arison_Kit.pdf
