Quick question
Old Oct 23, 2008 | 03:14 PM
Rover Curious's Avatar
Default Quick question
Being as this is my first Land Rover, cut me a little slack on this one. I have owned several 4WD vehicles in the past, but never one that was full time 4WD. Is it normal to hear your front propshaft turning? I have an '03, and the PO at some point replaced the u-joints with greaseables, which I greased this past Sunday when I changed the oil. The undercarriage seems exceptionally clean, and there's no noticeable vibration, it just seems that I can hear it turning when I'm driving at low speeds.
Old Oct 23, 2008 | 03:42 PM
NiteTrain's Avatar
Default RE: Quick question
if you can hear your driveshaft turning then something is wrong
Old Oct 23, 2008 | 03:44 PM
See if you can find out if the rebuild included a new centering ball kit also.
Old Oct 23, 2008 | 09:42 PM
Are you sure its the driveshaft that you hear? And not the gears in the t-case?
Old Oct 25, 2008 | 08:18 PM
I'm not exactly sure what I'm hearing now. I only seem to notice it when I'm coasting. If it's under load, I can't hear it even if I try. It definitely sounds like something turning, but now I'm thinking maybe it's not the propshaft.
Old Oct 25, 2008 | 08:34 PM
It is just your t-case I am sure. Check the fluid level in it.
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
mikemeyer0
Off Topic
Sep 27, 2005 07:08 PM
