R380 Manual Trans Fluid
Old Jan 25, 2010 | 12:08 AM
BajaXJ92's Avatar
Default R380 Manual Trans Fluid
The time has come to change the Manual trans oil in my Disco.
I'm just not sure how much to buy....
Will 3 quarts be enough?
I'm planning on using Redline MTL as I hear it can help clear up my funky 2nd gear synchro issue.
Old Jan 25, 2010 | 08:27 AM
antichrist's Avatar
2.8 qts, but I'd get a couple extra to allow for spills and/or not being able to get it all in from whatever you're using.
And yes, MTL is definitely what you want to use. There was a TSB sent to everywhere but the US to not use ATF in them.
Old Jan 25, 2010 | 09:58 AM
BajaXJ92's Avatar
Thanks!
Found it online for $9.99/qt on amazon so I ordered 4qts and got free shipping.
http://www.amazon.com/gp/product/B00...9A4E7584Y1V8Q8
Old Feb 6, 2011 | 04:32 AM
Dambo416's Avatar
3rd Gear
Cool R380 Gear Oil
I was interested to read your use of MTF in your R380, can anyone tell me why Land Rover recommend ATF Dextron II or III in the R380 when fitted to the 1996 Defender 300 Tdi, but they recommend SMX-S (which is an MTF) in the Discovery II fitted with the SAME gearbox but fitted to the Td5 engine ????
Surely AFT is much thinner viscosity than the SMX-S which I think is a W75 - 80 ????????????
Should I be using SMX-S in the Defender as well to make the box a bit quieter ?????
Alex - Dambo416
Old Feb 6, 2011 | 09:57 AM
A fluid change will most likely not help your warn out synchros. I would suggest you quit using the tranny for braking, brakes are a lot cheaper to replace then synchros.
Old Feb 6, 2011 | 11:12 AM
antichrist's Avatar
ATF was the recommended fluid for the early R380's. A TSB was published saying to switch to MTF.
There's no harm to a gearbox in downshifting when done right.
abran
Apr 27, 2014 06:59 AM
turtle97tj
Mar 23, 2010 04:36 PM
The People Family
Aug 6, 2008 10:32 PM
andrewassur
Apr 9, 2008 03:34 PM
bobsadog
Aug 22, 2007 02:50 PM
