Radiant Barrier
Old Mar 19, 2018 | 08:27 AM
Sixpack577's Avatar
Default Radiant Barrier
Started putting Reflectix radiant barrier in my 04 D2.
Going to do the entire interior, all the floor, firewall, all roof pillars, above headliner, and eventually inside the doors.
One 4'x10' roll did the back lower, up to the rear seats, and to the rear pillars.
My 04 D2 has been sitting 8 months now, while I fix 30-40 things. So I removed the rear carpet to access the fuel pump, and syphon out the old gas.
While it was apart, it was a good time to start insulating.
My D2's AC is excellent, but being black on black, you can still feel the summer heat, and the hot catalytic converters.
This will fix that.
I saw it posted here last year about putting Reflectix above the headliner. So I figured I'de do the whole truck.
I put Reflectix on my garage doors last winter, and a similiar radiant barrier in my attic.
I have been amazed at the insulating ability for heat, ac, and sound.
So here goes.
Pics coming.
Old Mar 19, 2018 | 08:31 AM
Sixpack577's Avatar
The Reflectix does not interfere with the carpet, plastic trim, or storage bins.
You can't tell it's under there.
Attached Thumbnails Radiant Barrier-20180318_141143.jpg   Radiant Barrier-20180318_141300.jpg   Radiant Barrier-20180318_181705.jpg
Old Mar 19, 2018 | 08:34 AM
Alex_M's Avatar
I think it's probably mine you saw over the headliner. Can't wait to see how much difference this makes.
Old Mar 19, 2018 | 08:36 AM
Sixpack577's Avatar
Attached Thumbnails Radiant Barrier-20180318_181726.jpg   Radiant Barrier-20180318_181744.jpg   Radiant Barrier-20180318_181711.jpg   Radiant Barrier-20180318_181757.jpg   Radiant Barrier-20180318_190129.jpg
Old Mar 19, 2018 | 08:37 AM
Sixpack577's Avatar
I will add to this thread as I get time to do the rest of the inside.
It should cost $200 max, to do the entire interior.
Old Mar 19, 2018 | 08:39 AM
Sixpack577's Avatar
It was!
I did my garage and attic and was amazed!
Then I saw your headliner post, and thought, that's genious!!!
Thanks Alex!
Old Mar 19, 2018 | 08:55 AM
Sixpack577's Avatar
It is noticeably quieter talking inside, and closing the doors it sounds, well, insulated.
Very happy with the results so far.
Old Mar 19, 2018 | 09:44 AM
jamestfl's Avatar
Looks great. Did above the headliner when in Florida, noticeable difference. You using an adhesive?
Old Mar 19, 2018 | 09:55 AM
Sixpack577's Avatar
Thanks.
No sir, no adhesive, just metal hvac tape.
Enough to hold it together and keep it in place.
The carpet, trim panels, and headliner will hold the rest of it.
Old Mar 19, 2018 | 10:03 AM
OffroadFrance's Avatar
Hi Sixpack
It's more or less the same insulation I used above my headliner, you'll certainly feel the difference in the summer heat, it's great stuff but be careful not to cause any shorts or fires on the electrical connections.
https://www.bricodepot.fr/saintes-sa...nts/prod35809/
PS: I paid less than half the current Brico Depot price for my insulation though, €3,30 M/2 I seem to recollect.
