Radiator Bleed Pipe
Old Dec 23, 2010 | 07:53 AM
oothejoo's Avatar
5th Gear
Default Radiator Bleed Pipe
My radiator bleed pipe just cracked this morning. I did a search and noticed some people have used fuel line to replace the bleed pipe...is this a safe fix or safe enough to work until I can order a new bleed pipe? If so, does anyone know the size of the line?
Thanks
Old Dec 23, 2010 | 09:00 AM
lipadj46's Avatar
Are you speaking of this?
http://www.roverparts.com/Parts/PCH000460G.cfm
Old Dec 23, 2010 | 09:03 AM
oothejoo's Avatar
5th Gear
No, I believe it is this part.
http://www.roverparts.com/Parts/PCH000360G.cfm
Old Dec 23, 2010 | 09:12 AM
lipadj46's Avatar
Sure I repaired mine with some 1/4" (or whatever size it is) fuel line hose hose until I could get to a Land Rover dealer. The part is like $20 from a dealer btw.
Old Dec 23, 2010 | 09:35 AM
oothejoo's Avatar
5th Gear
Okay, cool. Yea, I've got a quick trip coming up this weekend and just want to get it functional until I can pick the part up.
Thanks for the feedback.
Old Dec 23, 2010 | 11:35 AM
ljdiscovery's Avatar
just use the fuel or radiator line, it will work great, and will probably last much longer than the oem Land Rover part. Just be careful that the line doesn't kink as it comes out of the radiator or into the overflow tank. Same line will also work for the line that goes to the throttle body heater plate. Phil
Titus
Aug 10, 2015 06:17 AM
batiscan
Jul 4, 2013 05:02 AM
primussucks
Oct 11, 2012 08:56 PM
JavaDiscoII
May 29, 2010 04:33 PM
VintageEros
Mar 6, 2008 08:48 AM
