Radiator drain plug???
on
D2's don't have a radiator drain plug, best you can do is taking a hose off the t/stat if you want to drain most of the coolant.
By the way, where is your bleed screw, on the upper radiator hose or in a black plastic tee over by the alternator. If it is on the hose, buy the new up-dated hose assembly before you do anything else.
Do you then know how to bleed the coolant system to get rid of all the air and prevent over heating?
200 for the whole kit which u should get to bleed the system remove cap from resivoir and remove the little screw from the bleed hose,pour the coolant in until u see it coming out of the bleed screw in a nice stream.then put the bleed screw in and start the truck leave the cap off and put ur climate control to high the hottest setting,let it run for about 15 min to be safe and if it overflows a little no big deal its just purging air out but be sure to put it right back ingood luck bro
on
This is a got-to-be, the hose must be replaced and you can buy them separate from a full hose kit from Atlantic British .
on
Is there a different procedure for servicing the DI cooling system. I would like to do mine soon with a total hose replacement.
I took my oil seperator hose off, it was deteriorating on the inside. Rubber particles were coming out of the soft middle. I put heater hose on for now.
