Radiator drain plug???
Old Apr 15, 2010 | 11:40 AM
Sackou's Avatar
6th Gear
Default Radiator drain plug???
Hey I have a 2000 dicovery 2 and I wanted to drain my radiator the other day and couldn't find the drain plug. U guys have any Idea where it is?
Sackou
Old Apr 15, 2010 | 12:33 PM
D2's don't have a radiator drain plug, best you can do is taking a hose off the t/stat if you want to drain most of the coolant.
By the way, where is your bleed screw, on the upper radiator hose or in a black plastic tee over by the alternator. If it is on the hose, buy the new up-dated hose assembly before you do anything else.
Do you then know how to bleed the coolant system to get rid of all the air and prevent over heating?
Old Apr 15, 2010 | 02:31 PM
Sackou's Avatar
6th Gear
I think it's on the upper hose last time I checked. I don't really know how to do bleed the coolant system either. How much are the new updated hoses by the way?
Old Apr 15, 2010 | 02:40 PM
ROVERTECH15's Avatar
200 for the whole kit which u should get to bleed the system remove cap from resivoir and remove the little screw from the bleed hose,pour the coolant in until u see it coming out of the bleed screw in a nice stream.then put the bleed screw in and start the truck leave the cap off and put ur climate control to high the hottest setting,let it run for about 15 min to be safe and if it overflows a little no big deal its just purging air out but be sure to put it right back ingood luck bro
Old Apr 15, 2010 | 03:02 PM
antichrist's Avatar
FWIW D1's don't have radiator drains either. When I had my radiator recored I had them add a drain at the same time. I think it's stupid to not have a drain on the radiator.
Old Apr 15, 2010 | 04:34 PM
I thought they also cane with a drain, I know I helped a friend drain his D1 using a lower radiator drain plug, maybe it was also a replacement radiator.
Old Apr 15, 2010 | 04:37 PM
If you have the old hose and you try to remove the bleed screw, there is a good possibility that it will break and you won't be able to drive the truck till you at least buy a replacement upper radiator hose.
This is a got-to-be, the hose must be replaced and you can buy them separate from a full hose kit from Atlantic British .
Old Apr 15, 2010 | 04:52 PM
Danny Lee 97 Disco's Avatar
What did the recoring cost you?
Is there a different procedure for servicing the DI cooling system. I would like to do mine soon with a total hose replacement.
I took my oil seperator hose off, it was deteriorating on the inside. Rubber particles were coming out of the soft middle. I put heater hose on for now.
Old Apr 15, 2010 | 06:23 PM
antichrist's Avatar
It's been a while, but it was about $250. If your tanks are good then you can get a heavy duty core that provides better cooling. Even for the same price as new I'd do it as I've heard from several people that the replacement radiators aren't nearly as good as the original.
Disco Alan
Apr 21, 2009 06:22 PM
mburnett
May 28, 2007 09:18 PM
jacksyachts
May 2, 2007 11:49 AM
jwmstang
Apr 15, 2007 06:05 PM
anonimaus
May 1, 2005 05:01 AM
