radiator issue
Old Mar 21, 2010 | 01:20 PM
bt-dub's Avatar
Default radiator issue
Is there a common overheating problem with the radiators in the DII models? Im looking at a rig for sale and the guy has replaced the headgasket and it didnt help. He said he then talked with Land Rover and they said 90% of the time its the radiator. That didnt sound right to me
Old Mar 21, 2010 | 03:22 PM
http://sancarlosradiator.com/dex-cool.htm
Read though that.
All DII's came with Dex-Cool from the factory.
The common causes for a DII to overheat are blown headgaskets, cracked block, the cooling system not being bleed of air properly or a clogged radiator.
Unless you can get this truck for a song I would keep looking.
Old Mar 21, 2010 | 04:48 PM
00&04 Disco's Avatar
Ask the seller if he replaced the thermostat when he did the head gasket job. If the thermostat is stuck it could cause it to overheat. It is somthing to think about if you are not noticing the radiator leaking or the fans not working to keep it cool. Just a thought...
Old Mar 21, 2010 | 04:49 PM
Also, what year is it?
Old Mar 21, 2010 | 04:56 PM
bt-dub's Avatar
its a 2000. He said he recently replaced both the head gasket and the thermostat. Is there an easy way to check if it is a coolant clogg up like in the article?
Old Mar 21, 2010 | 05:16 PM
An easy way?
No.
You would have to do a complete cooling system flush and then do a flow test on the radiator.
If I did not own it then I would not spend the time and money to figure it out.
Old Mar 21, 2010 | 05:46 PM
bt-dub's Avatar
So is dex-cool still the coolant to use as long as you service it every two years? Or is there a better option?
Old Mar 21, 2010 | 06:30 PM
I HATE Dex-Cool, I used to sell bulk coolant and every mechanic I talked to, including Mr. Goodwrench mechanics all hated it too.
They used it if the car was under warranty but that was it, they drained it out of their own cars and used anything else.
Personally I like and recommend Peak Global.
The problem with Dex-Cool is that if it is exposed to any air it turns to goo and becomes corrosive.
Old Mar 22, 2010 | 09:19 AM
okdiscoguy's Avatar
An FYI, you can overheat due to blown head gaskets and drop a liner. It will still leak into the cylinder and you can't fix it without a new block.
You can take the truck to another mechanic and have the system pressure tested to see if and where it is leaking. It could be leaking at the throttle body heater.
If it is not bled properly, it will still overheat, even though nothing is mechanically wrong.
Dexcool IS corrosive IF it comes into contact with the atmosphere. It is only bad if you don't fix the problem, it doesn't create any problems. It just makes you fix problems as they happen.
Old Mar 22, 2010 | 01:46 PM
bt-dub's Avatar
Thanks everyone. This is a great forum. Ive used a couple forums in the past and this one definitely puts up answers the fastest. Needless to say, Im impressed. Thanks again
Alex_M
Nov 17, 2014 07:34 AM
nate2k5
Jun 3, 2012 05:49 AM
Kingmarine
Feb 26, 2012 09:27 PM
tunernewb92
Oct 20, 2009 07:15 PM
dms98e
May 9, 2008 08:36 AM
