Radiator leak
Old Dec 3, 2009 | 06:01 PM
Simonscyclist's Avatar
4th Gear
Default Radiator leak
Hey i need some Help, I have a leak its coming from the bolts under the airintake? I dont have a Tm, and when I was tightening it up i broke 2 of the three bolts. so first off can I bypass this and connect the two hoses together? if not what do I need to fix this; type of gasket and size bolts and were i can get this stuff from? thanks
2001 land rover discoveryII
Old Dec 3, 2009 | 07:21 PM
lipadj46's Avatar
That is your throttle body heater plate and depending where you live you can bypass it. Or just replace it for $25. And this time use a smaller wrench.
http://www.roverparts.com/Parts/MGM000010KG.cfm
noahsfortune
Feb 19, 2010 12:03 PM
Chrisinhouston
Jun 12, 2009 09:12 AM
rgrizzard
Mar 6, 2008 10:16 AM
2003Disco2
Jun 15, 2006 01:46 AM
ferrelltodd
Dec 8, 2005 02:46 PM
