Radiator/reservoir hose piece
So I had a pretty bad leak somewhere by/on my manifold on the drivers hand side and I was losing all my water/coolant and it would overheat. I was told for a temp fix till I could put the sealant needed on, to put this quick seal stuff in the water reservoir and it would block that spot temporarily. Today after driving it maybe 20 miles and parked, no leaks, I was happy... then I sat in my car while it was turned off, heard a noise then got out, all my water/coolant was on the ground. All of it. When I looked under the hood, the radiator hose connected to the driver hand side of the radiator had popped off, when I noticed that, I also noticed that the reservoir hose piece that wraps over the top of the radiator and hooks onto a piece coming out of the radiator right over the radiator hose, that had popped off as well. well not only did it pop off, the piece that it slides over had corroded inside and broke off. now that hose wont go back on because there is nothing to slide the hose over to keep it on. Im needing to know if because of this little piece, am I going to need a whole new radiator or does that piece have a name/number that I can look up and replace?
Thanks for any help
Thanks for any help
Most likely just a new radiator, in the $235 range and a few hours of DIY time. Do hoses and thermostat at same time. The "mechanic in a jar" fairy dust wonder seal super slick world's greatest goop has - blocked part of the radiator, maybe cause overheating, etc. When all apart also flush water in both directions thru the heater core.
D2 2003
11-07-2017 07:41 AM
bcolins
03-30-2014 09:02 PM
bcolins
07-29-2013 12:32 PM
Hyakku
04-10-2012 06:37 PM
Tim08
03-10-2012 10:05 PM
