Radio Code
Old May 20, 2019 | 06:19 PM
atebruce's Avatar
Default Radio Code
Have a 1997 Discovery !! - Just replaced the radio from another discovery (Junk Yard) Location unknown. How do I get code from an unknown radio. Tried all dealers - no help from them
Old May 20, 2019 | 09:57 PM
robertf's Avatar
The dealers can look it up. They need the serial number on the back of the radio or the vin it came out of. If you dont have those the only way to recover it is to partially disassemble the radio and read the eprom that stores the code with specialized equipment.
theres also an ugly hack you can do to sort of bypass the code. If you remove the eprom and leave it out the security code becomes press any button that isnt a number 5 times.
Old May 20, 2019 | 11:36 PM
ausGeoff's Avatar
4th Gear
I have the same issue with a lost code in my Disco II. Strangely, if I just hit number 1 four times in succession, the radio
comes on OK, but then switches off after 3 minutes—or if the engine is turned off. Start the engine again, do the same
procedure, and get another 3 minutes worth of listening LOL.
Faxdoc51
Freelander
Dec 11, 2023 08:30 PM
machinetech
May 6, 2013 09:00 PM
Lalioski
May 23, 2009 11:43 AM
DivebombInc
Mar 20, 2008 01:26 PM
yoeman
Jul 12, 2006 12:55 AM
