Radio Code Entry
Radio Code Entry
I was researching an old thread about radio code entry recently. I thought it might be a good reminder to post the procedure I recently found here.
If you lose power to the radio or disconnect the battery, then the radio must be reset with a factory code. Hopefully, you will have that handy. It is a 4 digit code, and initially you would think that the entry method is to use the radio digits 1 - 6 to make this happen. NOT the case. The first clue for me was that several of my digits are larger than 6. Hmm.
Ok. When you turn the ignition on, the radio display will initially show "Land Rover", followed in few seconds by "CODE"
Press "1" to select the first digit indicator. The display will show "0"
Press ">|" to step the number forward the proper code.
Press ""1" again to select and advance to the next digit
Rinse and repeat to enter all four digits.
Best Wishes!
Best Wishes!
