Which radio do I have?
The factory CD changer on a D2 does not use RCA's tho, it uses Mini ISO connectors
also, an aftermarket unit does not have the ability to power 11 speakers correctly, if at all, and it has no way to filter the frequencies like the factory amp does. You would need to add crossovers etc and the difficulty / cost would go up and up, and its just not worth it unless your a car hifi "freak"
ORIGINAL: Spike555
Well ok then, thank you for clearing that up UP.
I'm pretty competent with wiring and after market stereos. I am sort of of a hi-fi freak - in fact, the lack of poor midrange of the factory stereo in my Disco bothers me every day. I've been looking at a few options and I'm working on a plan to overhaul the factory system.
Urban Panzer, you say that the factory amp takes a low level input - do you think it's possible to connect an aftermarket deck's preamp outputs to the factory amplifer?
ORIGINAL: LambChop
That's why I was asking which head unit/audio system I have. I ran into this problem multiple times, both with an Infinity system I had in a Chrysler and a Bose system I had in an Oldsmobile.
ORIGINAL: Spike555
I "think" you wouldhave to use an aftermarket headunit wiht 4 pre outs not just 2 left and right, as they amp gets audio signals on all 4 channels FL,FR,RL,RR
