THE RADIO HAS GONE MAD!!!
Old Oct 21, 2006 | 09:24 PM
jmang's Avatar
Default THE RADIO HAS GONE MAD!!!
good day to you guys and gals
my radio/cd player in my 98 disco has gone weird on me. First it was in anti-theft mode (i couldnt touch it or it would beep for about 2 minutes..etc) so i disconnected the battery from the car (just negative terminal) reconnected after about 10 min and now the radio wont even power up. So i disconnected the entire battery for about 10 min and it still wont power up. Its supposed to blink code at me correct so i can push the radio code in? Or maybe something else is wrong. Any comments are deemed helpful. Thanks in advance.
j-mang
Old Oct 21, 2006 | 10:27 PM
Default RE: THE RADIO HAS GONE MAD!!!
Well, unhooking the battery wasn't and shouldn't be done as a means of fixing problems.
Bet thingh you can do now is unhook it over night and hook it back up to morrow, then try to enter your code.
Mike
Old Oct 22, 2006 | 04:28 AM
jmang's Avatar
thank you mr. mike for the quick response. I shall do that tommorrow night.
j-mang
Old Oct 28, 2006 | 10:05 PM
robbster91's Avatar
-bump-
any status? my radio is dead also, and it beeped before it went dead and no CODE message.
Also, now my cigarette plug and seats are dead????
Old Oct 29, 2006 | 02:05 AM
jmang's Avatar
sorry about the late response..been busy. But yes..i tried what you said Mike and its still dead. No blinking lights, nothing on the dash, just death. ANy ideas, or is this one of those only the dealer can fix things. Thanks in advance.
j-mang
Old Oct 29, 2006 | 07:14 PM
esaycho's Avatar
could it be a fuse, on my range rover a coin once got into the cigarette lighter and shorted out causing the fuse to blow, the climate control, radio cigarette lighter and i think the power seats went out
Old Oct 30, 2006 | 01:36 PM
robbster91's Avatar
Nope, new battery and fuses are good - - -
Funniest part is the drivers seat power works if I open the door ! lol
Old Oct 30, 2006 | 04:27 PM
jmang's Avatar
the driver seat has some sort of feature that only allows it to be moved when the driver door is open. the same can be said for my 98 disco. im gonna contact a dealer regarding the radio and let you know my findings.
j-mang
Old Nov 1, 2006 | 10:55 AM
alex of minnesota's Avatar
you may try removing the radio completely and having a good look at it. Most car audio will have a fuse in the head unit itself seperate from the main fuse in the underhood panel. if that one goes out, no radio.
Ranu2222
Jul 24, 2015 01:07 PM
LRScott
Apr 26, 2010 08:13 PM
stephenmmurphy
ROAMING WITH FRIENDS
Jan 14, 2008 06:49 PM
alex of minnesota
Nov 2, 2006 02:17 PM
