Radio help??
Radio help??
I have an 03 that had an after market CD player installed. It turns on but doesn't have any sound. They didn't cut any wires so I plugged the stock head unit in and it turned on also but doesn't have any sound. I want to go back to the original but I can't get it to play music. I checked the fuses in the cab fuse box and nothing was blown. Where should I go next? Do you think the amplifier is toast or does any one have any ideas? Thank you in advance.
I will look again but anything I found concerning the radio was very vague and generic. It showed a picture of a relay then a fuse then then the amp or the radio then fuse to amp but it didn't show where anything was actually located. I am guessing the fuses are under the dash but there isn't any relay that is labeled as a radio relay anywhere.
moocowman
08-31-2011 04:07 AM
bcolins
07-05-2011 08:30 AM
southfloridadiscoII
06-28-2009 11:03 PM
