Radio help??
Old Nov 15, 2013 | 08:39 PM
00&04 Disco's Avatar
Default Radio help??
I have an 03 that had an after market CD player installed. It turns on but doesn't have any sound. They didn't cut any wires so I plugged the stock head unit in and it turned on also but doesn't have any sound. I want to go back to the original but I can't get it to play music. I checked the fuses in the cab fuse box and nothing was blown. Where should I go next? Do you think the amplifier is toast or does any one have any ideas? Thank you in advance.
Old Nov 15, 2013 | 08:57 PM
The RAVE circuits manual is your pal. Wiring diagrams in living color, pictures of connector locations, etc.
Old Nov 15, 2013 | 10:52 PM
I will look again but anything I found concerning the radio was very vague and generic. It showed a picture of a relay then a fuse then then the amp or the radio then fuse to amp but it didn't show where anything was actually located. I am guessing the fuses are under the dash but there isn't any relay that is labeled as a radio relay anywhere.
dogstarsix75
Apr 24, 2020 01:33 PM
lvshust
Aug 21, 2018 02:29 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
