Radio Not Working...or Dead?
Old Jun 4, 2015 | 06:59 PM
newLRdiscov's Avatar
Default Radio Not Working...or Dead?
Hopefully someone can point me in the right direction, I've been searching to no avail for problems similar to mine. Recently I tried installing a bluetooth device on my 2002 Land Rover Discovery. I was given a connection kit and the direction was simply remove the blue 10-pin connector on the back of the head unit and replace with the kit connector for the bluetooth device. This is was I did. Once I connected the blue too the radio went berserk and would not turn off and none of the buttons worked (couldn't turn it off, volume, or change the station). So, I disconnected the battery because I needed to turn the radio off. Ever since then the radio has stopped working. The lights on the unit turn on (i.e., the buttons light up but the screen does not). Is there anything i can do to save this unit or is it dead?
Old Jun 5, 2015 | 06:34 PM
Externet's Avatar
Revert everything done to original condition and retry. There is an anti-theft feature that perhaps needs to be addressed for the radio to work again.
Old Dec 18, 2020 | 02:42 AM
Børre Gavle Aanensen-Bakke's Avatar
Default Solution?
I have the same experience on my Disco II 2001. Did you find a solution to the problem? Would be happy to get some hjelp on this one...
QUOTE=newLRdiscov;521461]Hopefully someone can point me in the right direction, I've been searching to no avail for problems similar to mine. Recently I tried installing a bluetooth device on my 2002 Land Rover Discovery. I was given a connection kit and the direction was simply remove the blue 10-pin connector on the back of the head unit and replace with the kit connector for the bluetooth device. This is was I did. Once I connected the blue too the radio went berserk and would not turn off and none of the buttons worked (couldn't turn it off, volume, or change the station). So, I disconnected the battery because I needed to turn the radio off. Ever since then the radio has stopped working. The lights on the unit turn on (i.e., the buttons light up but the screen does not). Is there anything i can do to save this unit or is it dead?[/QUOTE]
2008 LR2 Owner
LR2
18
Mar 26, 2022 07:10 PM
Dobbs
Range Rover P38 (2nd Gen)
Jan 21, 2019 07:23 PM
Jamie2333
Jul 12, 2018 06:39 AM
Rufflyer
Sep 15, 2017 12:53 PM
Oldtightloops
Nov 15, 2011 01:15 PM
