Radio Won't turn on - Fuses Fine
Old Mar 1, 2009 | 06:48 PM
tomfraser's Avatar
Default Radio Won't turn on - Fuses Fine
1995 disco
I was installing a new stereo (minus the head unit) and when I was splicing into the current wires I touched + to - and the radio shut off, no display / anti theft light
I went through and checked the main fuse panel (under steering wheel) the front panel (next to battery) the amp fuse (on amp under passenger seat) and they were all fine...
I've read of radios doing this after searching and no one ever had a solution
any other fuses i'm forgetting? Did I fry the radio?
Old Mar 1, 2009 | 07:13 PM
I think you fried the radio.
Old Mar 1, 2009 | 07:23 PM
tomfraser's Avatar
that sucks... i liked the stock look, i got a spare head unit so i guess thats going in
Old Mar 1, 2009 | 07:26 PM
tornado_735's Avatar
Originally Posted by tomfraser
1995 disco
I had an old Mercedes that had a fuse in the radio itself...maybe this one has one too, and it's blown. Worth a shot.
Old Mar 1, 2009 | 07:41 PM
tomfraser's Avatar
opened up the radio already... nothing
Old Mar 1, 2009 | 07:46 PM
Hmm...that stumps me then. Other than throw a bunch of sparks, did it make any popping sounds when you shorted it?
Old Mar 1, 2009 | 07:53 PM
tomfraser's Avatar
none whatsoever... it still blinked the antitheft light for like 10 minutes, and now it's not even doing that
Old Mar 1, 2009 | 08:09 PM
Maybe it's got like, an internal circuit breaker that just needs time to reset. Maybe it is toast. Try http://www.car-part.com ... IDK if they carry radios.
Old Mar 1, 2009 | 08:26 PM
tomfraser's Avatar
A piece of advice...
If you ever hire an electrician, and you find out he is british, RUN RUN RUN
my LEFT TURN SIGNAL FUSE BLEW, turn signals work fine, replaced fuse and so did the radio
GRRRRR
Old Mar 1, 2009 | 08:48 PM
GRRRRR
So you got it working? LMAO awesome dude.
