Raising suspension with SLS
Old Oct 15, 2007 | 11:50 AM
69mgb's Avatar
6th Gear
Default Raising suspension with SLS
I was just wondering if anyone knew of a way to raise my suspension height on my disco 2 with sls. I know with the Porsche cayenne's and VW Touareg's we can do it by modifying the ecu a bit, but i am wondering if there is a way to raise my truck without swapping the suspension. I am not looking for a 3 inch lift, just enough to run some taller tires. Any info is appreciated!
Mark
Old Oct 15, 2007 | 03:29 PM
ajh's Avatar
ajh
Default RE: Raising suspension with SLS
Yes, you can get some lift by raising the adjuster in the back, the ride will stiffen up though. A 1" lift kit from RTE is a better option though.
Old Oct 15, 2007 | 03:50 PM
69mgb's Avatar
6th Gear
RTE? What is that? Are there any mods i can do to the front as well or can i only adjust the rear height? Is there a write-up somewhere as to how much i can move the adjuster without blowing the air bags?
Thanks again!
Old Oct 15, 2007 | 04:13 PM
http://www.rovertym.com/
Their 2" spacer is the best way to go and very easy to install.
Old Oct 15, 2007 | 04:26 PM
ajh's Avatar
ajh
I may be selling my 2" lift kit. Send me a note and depending on how my conversation with Rovertym goes tomorrow I'll get you a good price.
Old Oct 15, 2007 | 07:37 PM
How much are you going to want for your SLS pump, and baggs?
Old Oct 15, 2007 | 08:02 PM
69mgb's Avatar
6th Gear
ajh, i sent you a pm for the lift kit. that pretty much means i have to swap to a spring/shock setup right? even if it is only a body lift? on my older cars i was able to give them a body lift by just installing spacers under my springs
EstorilM
Feb 13, 2010 08:30 PM
BajaBound
Apr 29, 2009 05:48 PM
jmohr10
Jan 6, 2006 08:22 PM
pbcarter66
Dec 4, 2005 08:11 AM
