Random codes at Random
Old May 4, 2018 | 05:11 PM
Richard Gallant's Avatar
Default Random codes at Random
Great title but apt description.
I get single random unrelated codes every now then (3 times so far).
1171 cleared never returned -checked all the sensor wiring no issues seen
Had an incorrect gear ratio code -DTC P0734 (twice) same deal check fluid level no problem the the transmission works fine
Had one other the day neglected to write it down but same deal no issues found.
This has lead me to check every single vacuum line, found a bad hose connection to the throttle body the connection is broke. Temp repair with red tuck tape. Issues with airbox the last clips have given up the ghost, once again temp repair with a bungie.
My suspicion is this where the bulk of my problems are, but could they also result for a bad ground ? I need to go over all them, as I found a few lose ones.
the connection for the small hose to the left is what is messed up
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
