Is the Range Rover 4.6 (P38) different than the Disco 4.6?
Old Jan 23, 2012 | 08:23 PM
toad2's Avatar
Default Is the Range Rover 4.6 (P38) different than the Disco 4.6? Could I put one in my 04?
This may be a stupid question and would probably be to good to true, but I am asking anyway.
Old Jan 23, 2012 | 09:00 PM
Depends.
Some P-38's used the GEMS engine, even came in a GEMS 4.6, later models used the Bosch engine.
So you will need to see a pic of the engine.
GEMS vs BOSCH Engines - Discovery I, Series II, Range Rover 4.0 & 4,6 - Tech Tips at RoverParts.com
Old Jan 23, 2012 | 10:34 PM
psykokid's Avatar
they are pretty much the same except that the crank position sensor mounting is different between the two. If you are looking to put a 4.6 into a D1 the GEMS 4.6 is the way to go. If you are going the other route and need a donor to fit into a later bosch motor car then it will require a little bit of modding..
Old Jan 24, 2012 | 06:13 AM
toad2's Avatar
I was thinking a RR 4.6 into my 04 Disco. I could pick one up, rebuild it at a leisurly pace and be ready when my 04 goes south. I am one of the tickin', bangin' Disco owners group!
Has anyone done this? Would there be computer issuses? Electrical issuses?
Old Jan 24, 2012 | 11:14 AM
yloDiscoII's Avatar
Subscribed
(...always wondered the same thing since there are many more potential donor P38's for sale than Disco's, in my area, for pennies due to electronics failures and such)
Old Jan 24, 2012 | 11:18 AM
toad2's Avatar
I was looking on Atlantic British site, the cam is the same, the crank is the same, the pistons and rings are the same, the lifters and pushrods are the same. It has to be the same engine doesn't it ?
I have already found one close by, just want to know for sure.
Old Jan 24, 2012 | 11:33 AM
psykokid's Avatar
overall its the same block as the 4.0, different crank and pistons are what makes the bump in displacement. IIRC like i said before i think the only real difference between the bosch and gems motors is the crank position sensor mounting. Same bore between both the 4.0 and the 4.6 blocks. I will defer to someone who has actually laid hands on a 4.6 block though..
Old Jan 24, 2012 | 06:10 PM
toad2's Avatar
Hey Spike, if it has the Bosch engine then it's the same?
Old Jan 24, 2012 | 06:20 PM
DiscoRover007's Avatar
Is the GEMS 4.6 better than the Bosch 4.6? I don't think I've ever seen an 03-04 Disco with a GEMS motor.
Old Jan 24, 2012 | 06:43 PM
yloDiscoII's Avatar
All DII's have the Bosch 4.0, the GEMS was in the DI's, so my guess is that the Rangie engines transferred over from GEMS to Bosch about the same time the DII came about.
