Ratling cat
Old Oct 30, 2019 | 06:25 PM
bmeier's Avatar
Default Ratling cat
I believe my driver side cat is going bad. Sounds like internal rattling going on inside it, Any recommendations on replacement cats? and/or o2 sensors... Thank ya.
Old Oct 30, 2019 | 09:16 PM
Frank4's Avatar
Old Oct 31, 2019 | 03:10 AM
JUKE179r's Avatar
Magnaflow #99004M, #93689, or #94105 as stated above.
Old Oct 31, 2019 | 05:22 AM
mln01's Avatar
When I thought a cat was rattling in my truck it turned out to be a failed exhaust manifold-to-downpipe gasket. It would make a noise only when accelerating. An $8 gasket was an easy fix; much less expensive than a new catalytic converter. You might double check those gaskets in your truck before springing for a new cat.
Old Nov 1, 2019 | 01:53 PM
bmeier's Avatar
I used a mechanics stethoscope and it is definitely coming from the middle of the driver side cat. As far as those magnaflows go, Do they require welding? I found a downpipe on amazon for about $290.00.
Old Nov 1, 2019 | 03:41 PM
Dave03S's Avatar
Often it is not just the downpipe gasket that is bad, the metal of the downpipe itself deteriorates at the welds on the upper part of the downpipe around the flange, which is what happened to mine. Complete Y pipes from magnaflow with cats are available, that's what I got, for around $450.
mtrdrms
Dec 31, 2012 07:30 AM
LRD2&ME
Jun 1, 2011 06:48 PM
pilsner
May 15, 2009 05:36 PM
SherryG
Dec 7, 2007 12:28 PM
JKK
Mar 4, 2006 01:29 AM
