Rattle from under truck from Catalytic Converter attn: Campcobb
Old Oct 6, 2009 | 03:58 PM
EVN137's Avatar
Talking Rattle from under truck from Catalytic Converter attn: Campcobb
Have a rattle from underneath. Metallic sounding, coming from catalytic converter.
Got underneath and examined. It was the heat shield. The shield is welded both
from and back. The front welding gave way resulting in a rattle.
Quick fix was done by arc welding the shield back on to the exhaust pipe.
Was done in-situ and as a result could only spot weld the shield where it is
accessible and not welded the entire contact point of the shield.
If you look closely at the picture, there is also a fracture at the weld line between
pipe and the cat. Need to do that too.
Note: a little tricky arc welding since the heat shield is very light gauge compared to the pipe
causing burn-through the shield, hence the splatter.
Ed
Attached Thumbnails Rattle from under truck from Catalytic Converter attn: Campcobb-dsc00371.jpg   Rattle from under truck from Catalytic Converter attn: Campcobb-dsc00369.jpg
Old Oct 6, 2009 | 08:26 PM
lipadj46's Avatar
Mine cracked a long time ago. I ignore the sound because I can't weld.
Old Oct 7, 2009 | 09:22 AM
kenk's Avatar
There's supposed to be heat shields there??? Hmmmm
zracin
Jan 23, 2024 10:19 AM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
