Rattle when accelorating
Old 02-11-2020, 06:28 PM
Frankenfriedl's Avatar
3rd Gear
Default Rattle when accelorating
Hello,
I recently purchased a 2002 Disco 2 with 191,000 miles for a $1000. It runs pretty good considering the mileage. Recently I have noticed a rattle like sound when accelerating and also when stopped and in drive. The rattle stops when I am cruising at speed and when in park. It also doesn't happen for the first couple of minutes when the engine is warming up.
Does anyone have any ideas of what this might be?
Old 02-11-2020, 07:07 PM
jastutte's Avatar
when the engine and exhaust are cold, crawl under the truck and check exhaust heat shields around the mufflers and the cats.
Old 02-11-2020, 07:11 PM
SundayFunday's Avatar
You can Check clearance of cat to frame
Old 02-12-2020, 10:37 AM
XRAD's Avatar
take a rubber mallet and hit the cats when hot and cold. Had a terrible rattle. turned out to be the cats, but sounded like the drivetrain.....
Old 02-13-2020, 06:09 AM
3rd Gear
Thanks for the suggestions. I'll check out the cats and heat shield today and let you know how it goes.
Old 02-13-2020, 06:42 PM
3rd Gear
So I gave my cats a good look and I'm still not sure if that is the problem. A little more info on the rattle... It starts after the vehicle is warmed up. It only happens when accelerating or stopped. If the car is running and in park the rattle stops. If the car is in neutral the rattle stops. But as soon as I shift into drive the rattles starts back up. Does that still sound like something the cats could cause?
Old 02-14-2020, 07:14 AM
Sounds a lot like your first post.
get someone to put truck in drive at idol (use chalk block) & have a look yourself once warm.
Old 02-14-2020, 08:17 AM
XRAD's Avatar
could be transfer case or driveshafts, rattling a bit when in gear.... have you greased your driveshafts lately...or put a heavier weight oil into transfer case?
Hopefully not the trans.....
Yes, you could have this sound from cats when in drive because the engine load changes a bit and therefore engine vibrations change a bit too... do the mallet test.
Old 07-24-2023, 03:31 PM
Stanimal's Avatar
This happenned to me it was the harmonic balancer - it was very loose.
Originally Posted by Frankenfriedl
Hello,
toofaroffroad
01-31-2020 10:54 PM
aublec22
01-27-2008 11:31 AM
hollis
08-27-2007 03:17 PM
flygirl92
05-15-2007 07:28 PM
jcostello
10-27-2006 03:39 PM
Quick Reply: Rattle when accelorating
