Re: #8 Cyl misfire 2004 LR Dis SE7
get a compression test done or do it. You should see numbers around 155.
You if the compression is bad have them try a leak down test to help pi point issue.
If compression is good it could be a a fuel supply issue since it is one cylinder, more than likely fuel ejector, but if it is fuel related it should be throwing other codes.
