Re: #8 Cyl misfire 2004 LR Dis SE7
Old Dec 29, 2013 | 09:26 AM
Lcbjr's Avatar
3rd Gear
Default Re: #8 Cyl misfire 2004 LR Dis SE7
I am done it all, replaced wires, coil pack, plugs, and still I have a #8 cyl misfire
Old Dec 29, 2013 | 12:01 PM
mbruneaux's Avatar
Any codes? Compression test ? Possible injector?
Old Dec 29, 2013 | 05:42 PM
xxdoylexx's Avatar
get a compression test done or do it. You should see numbers around 155.
You if the compression is bad have them try a leak down test to help pi point issue.
If compression is good it could be a a fuel supply issue since it is one cylinder, more than likely fuel ejector, but if it is fuel related it should be throwing other codes.
Old Dec 30, 2013 | 09:36 AM
Lcbjr's Avatar
3rd Gear
Default #8 cyl Misfire
Yes my code is 308, I have yet to get compression test, thanks
Old Dec 30, 2013 | 09:37 AM
Lcbjr's Avatar
3rd Gear
Default # 8 Cyl
Ok thanks, Ill jump right on this
bmeier
Jul 17, 2014 03:25 PM
dbliz1
Aug 29, 2013 02:45 PM
tbesselman
Nov 17, 2006 01:20 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
