RE: OBD is KIA
RE: OBD is KIA
Well, the best laid plans of mice and men, often run awry... So, I got replacements, ECM/BCU combo from the Rover wrecker in SC on Friday afternoon... Read the R&R instructions in the RAVE, followed them, plus a suggestion from Savannah, ie: keep the hood alarm button depressed.
That was all easy enough...one snag, all the dash lights fired up, but the starter was MIA. So, re-installing the original ECM/BCU, and presto-painto, the rig is back to running as poorly as ever...but, at least it is running.
I didn't attempt to read any codes on the replacement ECM/BCU, figuring, I think, it takes about 20-30 minutes to develop any...
Any help here, would be really welcome!
Thanks
Thanks
oH, wELL...Swapped them out and tryed thte key trick...no such luck! The key didn't work...and the $@#%@#%^thing wouldn't start! The panel lit up like a christmas tree, but that's all it did...
I swaqpped them back and low & behold it did/does run better, not great, but better...
I'm tempted tp start switching/ mixing the pairs...Would that screw them up? I've tagged them all.
