RE: OBD is KIA
Old Jun 2, 2012 | 02:03 PM
onewingman's Avatar
Default RE: OBD is KIA
Well, the best laid plans of mice and men, often run awry... So, I got replacements, ECM/BCU combo from the Rover wrecker in SC on Friday afternoon... Read the R&R instructions in the RAVE, followed them, plus a suggestion from Savannah, ie: keep the hood alarm button depressed.
That was all easy enough...one snag, all the dash lights fired up, but the starter was MIA. So, re-installing the original ECM/BCU, and presto-painto, the rig is back to running as poorly as ever...but, at least it is running.
I didn't attempt to read any codes on the replacement ECM/BCU, figuring, I think, it takes about 20-30 minutes to develop any...
Any help here, would be really welcome!
Thanks
Old Jun 2, 2012 | 02:10 PM
Sounds like new parts were thinking they were in alarm or immobilzation. Do you have a key fob to lock/unlock several times, etc? BCU controls starter relay.
Old Jun 2, 2012 | 02:13 PM
Opps - forgot - if you had read codes or data from OBDII port when new ECU was installed, that might mean that rest of wiring harness and other modules are not part of the original problem.
Old Jun 4, 2012 | 10:04 PM
onewingman's Avatar
oH, wELL...Swapped them out and tryed thte key trick...no such luck! The key didn't work...and the $@#%@#%^thing wouldn't start! The panel lit up like a christmas tree, but that's all it did...
I swaqpped them back and low & behold it did/does run better, not great, but better...
I'm tempted tp start switching/ mixing the pairs...Would that screw them up? I've tagged them all.
Old Jun 4, 2012 | 10:06 PM
You can try, but I suspect BCU will want to talk secuirty codes to ECU.
onewingman
Jul 23, 2012 06:31 PM
onewingman
May 25, 2012 04:03 PM
onewingman
Feb 25, 2012 04:55 PM
GreedyRover
Off Topic
Sep 28, 2011 03:26 PM
alemurill
Jul 9, 2008 10:16 AM
