re: Service Engine Soon
Old Feb 6, 2008 | 06:37 AM
georgetrieste's Avatar
Default re: Service Engine Soon
Mike,
I got my codes read last night. The code was P0455, Emissions???. I took it to big o tires. The guy said is had something to do with the gas cap. He went ahead and reset the light. Does this sound right to you?
Thanks,
George in Castle Rock
Old Feb 6, 2008 | 08:46 AM
S4poor's Avatar
Default RE: re: Service Engine Soon
This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Symptoms
You likely won't notice any drivability problems.
Causes
A code p0455 most likely means one or more of the following has happened:
[ul][*]A loose or improperly affixed gas cap[*]A non-conforming gas cap (i.e. not factory/original brand)[*]Other leak or damaged piece in EVAP system [/ul]
Possible Solutions
With a p0455, the most common repair is to:
[ul][*]Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.[*]Otherwise, replace the gas cap, and/or[*]Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary [/ul]
Old Feb 6, 2008 | 08:54 AM
DITTO!!!
Old Feb 6, 2008 | 09:15 AM
Have removed and replaced gas cap and reset code. Now it is wait and see.
Thanks,
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
AMANDAMC
Sep 23, 2007 11:14 AM
hippo2002
Freelander
Dec 19, 2005 01:31 AM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
