Real time help needed! Vibrations!
CDL = central diff lock on the transfer case. You have a 2001 and it could have CDL, not all of them do. You need to feel above the front output shaft for a nipple, this allows you to lock the CDL. If you can lock it then you can pull the front drive shaft and do a test drive to see if the vibrations are gone.
Some useful CDL info here: http://www.landroverclubvi.com/2003cdlinstall.html
Look here for rebuilding the drive shaft: https://landroverforums.com/forum/sh...ad.php?t=29302
