really stuck and not sure what to do.
Old Feb 4, 2010 | 01:22 PM
Rover Chris's Avatar
Default really stuck and not sure what to do.
so I am trying to remove the rubber piece inside of the rear prop shaft and replace it with the new one that came with my rotoflex. it is stuck and I can not get it to budge, is this piece pressed in and I need a puller to remove it or something? and when I get it out do i need a special tool to press in the new one? I have torn it up a bit trying to get it out so now it needs to come out!
Old Feb 4, 2010 | 03:47 PM
leadfoot's Avatar
I used a chisel to cut it down all the way on one side, then it was easy to pull it out with a pair of locking pliers. The new one, I just hammered in with a piece of wood and a hammer. No sweat. Is been there for 30K now.
Old Feb 4, 2010 | 05:09 PM
been trying to do that all day, I guess I will try a little more
Old Feb 4, 2010 | 05:10 PM
okdiscoguy's Avatar
spray some penetrating lube on it...
I can't really help you, I got a 97 influence by BMW. No Rotoflex....
Old Feb 5, 2010 | 10:20 AM
leadfoot's Avatar
Default Bigger hammer
Oh, come on. All day? just get a bigger hammer and sharpen that chisel. Let the cave man in you come out.
Old Feb 5, 2010 | 06:57 PM
Urban Panzer's Avatar
or use a slide hammer, comes out easy then !!
Old Feb 5, 2010 | 10:23 PM
bigger hammer and a new chisel worked pretty well, unfortunately got the whole thing back together and I am still feeling the vibration under acceleration. Anyone got any ideas of what I should check next?
Old Feb 6, 2010 | 06:22 AM
AK Rover's Avatar
Check all your u-joints
Old Feb 6, 2010 | 10:42 AM
leadfoot's Avatar
Oh, that is a whole new piece of information. How certain are you that the vibration is coming from the rear end and not the front? You may have posted before and I missed it. I assume you already ruled out the obvious, tires wearing uneven, tire balance, bent wheel, wheel bearings.... what have you ruled out so far?
Old Feb 6, 2010 | 11:50 AM
I can send you a PDF file on how to rebuild this if you want it send me your e-mail address.
aussiestuckintexas
Nov 2, 2014 02:04 AM
k75ssk
Jul 10, 2014 06:37 AM
powderhound
Jul 7, 2014 10:51 AM
ImQuattro
May 1, 2014 08:36 PM
range_time
May 5, 2010 02:19 PM
